FLANK wrenches and sockets
Aqualab
- Your Location: Upstate NY
Hi - can someone please tell me what FLANK refers to? Thank You
- snapy64
Re: FLANK wrenches and sockets
Flank drive was invented in the 1060's by Snap-on for the Navy to apply high torque to bolts on aircraft without stripping. It refers to applying the pressure to the flat side or flank of the bolt or nut, conventional tools applied the pressure to the point which caused stripping.
Flank Drive refers to the closed end of Snap-On wrenches (and sockets) and the shape directs the force away from the corner of the fastener, to help prevent rounding off.
"Flank Drive Plus" refer to the teeth on the open end. So, the Snap-On Flank Drive wrenches (without the Plus) have no teeth.
Bill_Houghton
- Your Location: Sebastopol, CA, just off Main
Where's the fun in that? You never get to demonstrate your skills in removing nuts that have been destroyed that way.snapmom wrote:...the shape directs the force away from the corner of the fastener, to help prevent rounding off.
Aqualab
Thank you guys - appreciate the replies and information!
