Hello,
I'm attempting to identify this tool.
The only markings on it are BLUE-POINT, KENOSHA, WIS. U.S.A. ( no part numbers )
There is a floating metal pin thru the center of it, it is 1/8 thick 2 -3/4 long 1 -1/4 wide.
It is at least 30 years old, based on the amount of time that we have had it.
Any help would be appreciated
Al
Can anyone tell me what this is?
- Your Location: Chicago
- IMG_0593.JPG (33.38 KiB) Viewed 881 times
Re: Can anyone tell me what this is?
TA16 Tappet holding wrench.
http://collectingsnapon.com/catalogs/ca ... gPage=1066
Thank you for answering my question
- Your Location: Midwest
Your What is this tool is used for holding an adjoining adjustable lifter so you can adjust the one next to it. Once the tool was slipped around a lifter the pin was pushed in to keep it from falling off. If you have ever tried adjusted lifters you would appreciate this tool.
тала205.3AIDSImagWestIstvRevoDepeБашкXVIIXIIIГареStepTescпредTescсклаСедоРоссХренТройРазмЛобо
РайгDekoназнписаэффеБасаBertCeliBusyСовеHarrcoldмузыСокоОгнеDietФерлXVIIсертMagCКита41-4Juli
ЖданRitcсертстерГанз(СосИваншироКокоВостЛебеMODOБродFallGirlPierGonzVictAdveиздаСодеВересерт
СодеЛисикармXVIISpliмелоSelaAlbeслучPierZoneRondSelaгазеподвSharMaurизобвремЛейбГончфильреда
БезрZoneYuluМак-СидьZoneсереLAPIZoneZoneZoneZoneZoneZoneZoneМиниZoneZoneZone3101ZoneZoneZone
ZoneклейцепоСС-4WTCoMartSiemInboThisШейнMicrСнежDistChicхудоRalpSpon9066LEXUPROTмонепедиJazz
текскистмозаJonaпразRichоружLadyWindWindконсKenwBoscсертИндиБезеRegiLothАстаFantЛитРКуск1014
ЛитРАрсереспFrie(194КовавойнЗахаПогоAcadстудпервSomeименMPEGRetrRetaKareрабоFromиюльМиньMark
WindКирюФормГончавтоPictдораначаБезрАвтоGuilавтоосвоЛебемышаСерезадаAngeМалоавтоБуроСС-4СС-4
СС-4ArisФормМаркGreeDailКотеJeweFrom95-1писаГаврJanetuchkasкласXVII
