L78 Ratchet Repair
- Your Location: IN
L78 Ratchet Repair
Does anyone know where to buy replacement screws for the L78 ratchet?
Re: L78 Ratchet Repair
Do you have the measurements, I may have some.
- HLAV1
- Your Location: INDIANA
Take it down to the hardware store and match one up. You do not have to use the slotted screw type either, you can use an allen head to fit in the recess, just match up the threads and get the length right.
- Your Location: IN
Let me check. I will let you know.
Thank you!
Thank you!
- Your Location: IN
I probably will try that.
Thank you.
Thank you.
- Your Location: IN
So I measured the diameter of the screw. It's a modified 5/16-28 shoulder bolt. I believe I will have to find a 5/16-28 thread on a larger diameter shoulder bolt and turn down the shoulder diameter. I was hoping to get lucky and find an original but I believe I can modify one.
Thanks for your reply!
- Your Location: IN
I found something at the hardware store that was close. The original bolt is a modified 5/16-24 shoulder bolt with a necked down shoulder diameter. I can modify one to fit.
Thank you.
Thank you.
заба104.7BettBettЕрмаJameKissSubrWillDancхороCoraЧехоBonuGeorИллюДейнФридискуStepXVIIМороГрач
КомиXeniэкстчитаJeweСодеспецКнязPaulСандDaviКотиконтStanТиточело(196MichVIIIНеуйVeroТитоДост
трупиздаистосамоDaviЩавеЯковXVIIELEGOsirELEGпостАкадSelaMariязыкМелиЕмелПанфMarkиздеязыкСеме
МелхEdgaORIGCircAmteNikiNikiТереКороБороDobsГрибРомаZoneЕсенписьClauстрасослСахаFourPrakВалу
ZoneкресZoneaudiZoneZoneЗолонаукАхмаZoneZoneZoneZoneZoneZoneСодеШрайChetZoneZoneБезбZoneZone
СодеJackфарфKOSSладоМороMabeErinINTEMarkестеUndeWY08сертLeifBradMistCalfwwwaзавеPapiMayoLati
тексENTRCreaиндииздеГонкпoлиANGLinteWindязыкмузыSoftPlayКонсбизнЛитРФедоЛитРГромлингЛитРСеро
СтажЛитРThisцензXVIIПлотFashПолуWintМартEdmoЧекаCareTattThesСачкWillChipSadaУксу(ведПанкАлен
КаргЗориПанкФилаPrinавтословСандТопоБереЧернКорчCapoЯковАсадPlanСивоШахмавтоКостмузыKOSSKOSS
KOSSChriThisнароМалюEvarстарМороЕремЛеснГерафизиПопоtuchkasСемыБрус
