help!!! how do you remove the soft comfort grips off of ratc
davidgrimes20
Your Location: Fort Lauderdale, Florida
Post by davidgrimes20 »
Hey im David and this is my first post. I need your help, Id really appreciate it.
I have the FHBF80 Ratchet, Dual 80® Technology, Bent Flex-Head, Comfort Grip, 3/8" drive, 13 5/16" it has the red and black soft grip on it and id like to put the same grips on it but different color. Now id also like to do this on a 1/4" and a 1/2" flex head quick release. They all came with the same red/black soft grip. Please respond on how to remove and install the soft comfort grips without scratching up the ratchet or new grips. Thanks guys.
ranger
Your Location: newyork
Re: help!!! how do you remove the soft comfort grips off of
Post by ranger »
Hello. I had to have the guy on the truck do it. He has a special press on there that pulls the old one off and presses the new one on. They are on there pretty good!
For soft handles:
1: boil some water
2: put the handle of the ratchet in the water for about 3 minutes
3: using hot pads(the handle Will be hot ) hold the head of the ratchet in one hand and pull with the other hand on the handle
4: align handle and drive on with a deadblow
ranger
Post by ranger »
Never thought of that! I struggled the first time! Then had my buddy on the truck do it. Thanks for the info.
davidgrimes20
Im impatient and dont want to wait for the SO truck to come. I did hear from someone you could do the hot water trick. Just wanted to hear it from someone else though. Thanks guys.
