What is a 119TMPB ?
Posted: Fri Jan 30, 2015 9:48 am
by bdub
Recently inherited this set. Can't find it in any of the catalogs.
Any comments/thoughts would be helpful.
Thanx in advance!
119TMPB
Contains:
11x TMMD - sockets 5mm to 14mm
10x TMD - sockets 3/16” to 9/16”
TM 10 F - Spinner
TMU 8 - Universal joint
TM 70 B - Ratchet
TMX 2 - Extension bar
TMX 4 - Extension bar
TMX 60 - Extension bar
TM4 CS - Plastic grip handle
PB 24 - Plastic Case
Re: What is a 119TMPB ?
Posted: Fri Jan 30, 2015 7:15 pm
by macother
What you have there is a versatile little 1/4" general service set. Mid 70's to early 80's in that configuration, the TMD and TMMD are 12 point. It's a great 1/4 set, has the right variety of extensions, and if you add a longer handle ratchet, it can spin just about every small fastener you're likely to run into. See if there's a date # on the ratchet, it's in the middle between on/off, under the lever.
Posted: Sun Feb 01, 2015 2:18 pm
by bdub
Macother - thanx for your speedy & accurate reply.
As far as a date number on the ratchet, it looks like a "4" in-between the 'ON' & 'OFF' words.
Is that some kind of a date code?
Off 600.jpg (143.98 KiB) Viewed 1241 times
On 600.jpg (162.3 KiB) Viewed 1241 times
Thanx again for your help on this!!
Posted: Sun Feb 01, 2015 4:05 pm
by macother
That's right, it's 1984. Take a look under the resource tab here at Collecting SnapOn to find the date chart. Also take a look at the sockets, you may find what looks like spurious single numbers, they're actually the date stamp. Not all sockets have them, and in older sets, the numbers might not match. As for the 119TMPB, the nomenclature for the sets is difficult to follow, and it sometimes has a bearing on what's in the set, but it's usually greek to me.
