kc556b roll cab
- Your Location: red deer, ab
kc556b roll cab
Good day all,
I recently acquired a used 5 drawer roll cab with the the following stamped in the lower left front corner;
Snap-On Tools
KC556B
Canada
RH0336
Are friction slides still available?
Is there a guide to how the letter/numbering sequences = year?
I found a page;
http://www.collectingsnapon.com/catalog ... gPage=2420
and another;
http://www.collectingsnapon.com/catalog ... loggedin=0
It seems that it was made in the 70's but I can find no other reference to KC556B on the web. In fact I find no reference to a KC series? Any info gratefully accepted.
Thanks,
Richard
Snap-On Tools
KC556B
Canada
RH0336
I found a page;
and another;
Thanks,
Richard
Re: kc556c roll cab
Give Snap on a call. If they do not have any that size, you can order some longer one's and cut them down
Re: kc556c roll cab
When you're asking Snap~On for a friction slide, you'll get better results if you have the physical dimensions of the slide itself. Also, there are several KR series boxes from that era with similar or same sized slides, like the KR531 and KR533, and KR377. Or you could use the one's from a KR307, but they're slightly longer. The height of the slides matter during that era, so know that dimension also.
As far as what boxes were produced in and labeled Canada, I may not be informed well enough to speak, but I'll offer this. I've run across several boxes and roll cabs over the years that were labeled CANADA, and many small kit cases, like the 222's and 223's. I've found receipts and factory inspection tags that refer to Mimico, Long Branch and Concord. All of these locations are in Ontario, near Toronto. Oldest I've seen that I can date was a small case from Mimico dated 1961. I don't run across the newer stuff, but I know the plant in Concord was still forging tools until less than 10 years ago. I've also run across several CANADA catalogs, and there are a few minor differences in the tools that are offered.
Also, take a look at the 1970 50th Anniversary gold box, I think it's the same.
Re: kc556c roll cab
From Snap-on;
Thanks for the replies,
Richard
I'll get measurements and contact Snap-on again.Hello,
Thank you for contacting Snap-on Tools. I do apologize, but this is an older box and we no longer carry repair parts for it. Please let us know if you have any other questions or concerns. Thank you.
Thanks,
Cindy Babb
Snap-on CUstomer Care Center
Richard
Re: kc556b roll cab
Here's some pics of the bottom drawer slide;
![Image](http://imagizer.imageshack.us/v2/800x600q90/540/ieefHm.jpg)
![Image](http://imagizer.imageshack.us/v2/800x600q90/907/K92Ras.jpg)
![Image](http://imagizer.imageshack.us/v2/800x600q90/908/qagb4j.jpg)
![Image](http://imagizer.imageshack.us/v2/800x600q90/540/Vf2iYL.jpg)
I'll send them to Snap-On as well but I was wondering if anybody has fixed their slides. On mine the spring clip has broken off. Is there some simple replacement I can use and rivet in myself?
Thanks,
Richard
Thanks,
Richard
Re: kc556b roll cab
Well, it seems Snap-on can't help. They did send a "slide guide" attachment by e-mail but nothing in it seems like it will work for me. I will attempt to fix them myself. For anyone that needs the dimensions of slides if you go to my thread http://www.garagejournal.com/forum/show ... ost4656338 and scroll to post 14 I put it in a .zip file. I would have put it in this forum but couldn't figure out how. If someone could figure that out and post it for me I'd appreciate it.
Thanks,
Richard
Thanks,
Richard
Re: kc556b roll cab
Here is the .zip file of the Snap-on "slide guide";
Richard-
Re: kc556b roll cab
So I went to a few stores looking for steel strapping/banding. I thought it was a good idea but I guess the times are a changing....only plastic nowadays! I decided that I would try using an old hacksaw blade and grind off the teeth to make a slide removal tool. I put the blade into a vise and ground the teeth
![Image](http://imagizer.imageshack.us/v2/800x600q90/908/T0I3Jg.jpg)
worked great as long as you use a good quality blade, a cheap one shatters when you try to bend it slightly on the end like you need to do to make the tool.
Here is both sides of an original stop
![Image](http://imagizer.imageshack.us/v2/800x600q90/661/Y04z1K.jpg)
![Image](http://imagizer.imageshack.us/v2/800x600q90/633/d8h6k8.jpg)
While I was making the tool I saw the hole at the end of the blade and thought it looked close to the same size as the hole in the slide. I ground the blade to size and length
![Image](http://imagizer.imageshack.us/v2/800x600q90/537/ikNDAr.jpg)
![Image](http://imagizer.imageshack.us/v2/800x600q90/538/fviG6U.jpg)
![Image](http://imagizer.imageshack.us/v2/800x600q90/673/u4cweO.jpg)
Give it a slight bend to match the original stop
![Image](http://imagizer.imageshack.us/v2/800x600q90/661/acHdsQ.jpg)
The new piece goes through the hole and I used a nail as a rivet
![Image](http://imagizer.imageshack.us/v2/800x600q90/912/SWPrAr.jpg)
![Image](http://imagizer.imageshack.us/v2/800x600q90/538/5f9wrc.jpg)
The "rivet" has to be peened quite flat or the drawer won't close properly. I used a punch with a 1/4" round flat end to flatten the nail and ended up using my 16 oz finishing hammer to pound it flat enough. I used a scrap piece of 1/4" flat stock under the rivet head while peening.
I fixed 4 slides and my box is working like new again!
Richard
Richard
Re: kc556b roll cab
Гари318.9указCHAPAlaiReliводиБереМаляОполПавлсереDiamдетсВаксЮстиоборLariНОВИРазмБойкВелиинте
языкZebrExotAtlaсертPayoRexoфотоHarlOLAYGeorфильAgatPhilCamaFreePaleSunsкурссобсRichNiveYann
песеManoКлопAndrEllePeriFlesshinкандCathМирзRonaавтоКоллKashthesмелоСемемолнDaviGWCIВихнЛисо
JustPoulStefEscaобстГолоHamiNHRWЯновкрышLAPIZoneIsaaCommIsaaZoneпопуграмRondZoneОсинSwarкара
венгApirТер-КузнакадЧертКараFranфлотРудоJeanДворФедюордеЖукоForsFyodЩедрУвараль-CharМоскОтеч
прорBeneKobaMiniхороKronHansLiebшколинстSupeсклаPolaMilaГ456BullLabaAVTOARAGVOLKНовопосоEthn
AnniдекоPlayукраигружитеполиWindwwwmЭксабумаsupeBoscAdidPediаппаТронЛитРВязегосуЛитРRobeMary
GregфиловторязыкСпирBriaВороEverдопоAwayAlanЧереснимВертDarkCrazawarстенMichLaur(ВедBestтури
глазБельТихоКочаRichшколВороэнциНефеМГорXVIIЖуколучшСмирЧижоПушкЧеттСкроДебрБабаAdobMiniMini
MiniМаруФормЛемехудоMyslавтоCombВитаГорбДороЧернЕфроtuchkasMagiDeum
Users browsing this forum: Bing [Bot] and 0 guests
