Dating the 707 set
Dating the 707 set
This is a way to date the 707 set. On the insert it list additional tools you can purchase, the prices match the 23 cat, but not the 25. The insert also shows the extensions with a two ball stops, which as far as the 5/22 ads show the pinched stops. Also the sliding tee measures about the same size as the 10" extension, and shows pinched stops. So the most probable date for the 707 is 23-24, with 23 being the most probable.
- IMG_6099.JPG (148.98 KiB) Viewed 737 times
- IMG_6096.JPG (197.92 KiB) Viewed 737 times
- IMG_6100.JPG (191.59 KiB) Viewed 737 times
- IMG_6095.JPG (238.83 KiB) Viewed 737 times
- IMG_6098.JPG (198.74 KiB) Viewed 737 times
rdwaaw
- Your Location: Minnesota
Re: Dating the 707 set
Amazing condition!!! Should have an armed guard for it!!!
The brace drawing caught my eye. Looks like a short speed handle.
Thanks again!
Thanks again!
