Fb50 set
Fb50 set
I have been collecting some ferret stuff for a while and have come across a couple of Fb50 cases. One has the Oval decal and the other a triangle style decal. I assume the Oval is earlier but I have seen it on some later stuff. Was there some overlap on the use of these? Boxes are otherwise the same.
- 20171022_134050-1032x581.jpg (151.87 KiB) Viewed 512 times
- 20171022_132940-1032x581.jpg (139.85 KiB) Viewed 512 times
- 20171022_132948-1032x581.jpg (126.83 KiB) Viewed 512 times
Re: Fb50 set
Usually the oval is earlier, but I have seen the triangle on late 30s too.
