Blue Point Open End Ratchet Wrenches 7 pc set.
Posted: Fri Apr 13, 2012 12:49 pm
Usually when you find this set, its a four piece set, but for a few years in the late 40s they made a seven pc set. Not sure when they changed to Snap on from Blue Point. This set has dates from 47-49. There are three diff variations in the attached set of seven. Model numbers RS-1012 thru RS-2428. These seven show up in the 48 and 50 cat.
