Number 3 handle question
skipskip
Your Location: upstate NY USA
Post by skipskip »
did the number 3 Tee handle come without the spinner sleeve?
Or was it only the shorter number 2 that was sleeveless?
thanks
Skip
Re: Number 3 handle question
The early No. 3 did not have the sleeve.
skipskip
Post by skipskip »
So , in time order
Sleeveless
sleeve with pinched shaft
sleeve with detent ball stops
correct?
thanks
skip
There is a three ball stop, a one ball with four pinches, and a one ball with two pinches. The two pinch is very rare.
skipskip
Post by skipskip »
I have my pinches and balls confused.
one of mine has what look like balls on the shaft rather than pinches
some of the ends where the socket goes have 3 balls , one has only one
here are pics of the three I have
http://www.flickr.com/photos/skipskip/s ... 477308488/
Four types of drive ends. two pinched, four pinches, three ball, collar.
Four types of center grips. no grip, pinched, ball (large width grip), ball ( small width grip)
skipskip
Post by skipskip »
Perfect!!
Thank you
these apply to speeders too?
anything else?
Skip
the socket ends apply to speeders. but the balls go internal with the ones with grips. There were many speeders with no center grips early thru current.
Users browsing this forum: Ahrefs [Bot] and 5 guests
