what is this??
tsmith1
what is this??
I found this with the clutch tool if the picture comes out also I am trying to post the other stuff in the box Thank you
- 1999_0304tools0021.JPG (130.26 KiB) Viewed 2059 times
tsmith1
Re: what is this??
this is the rest of the stuff from the box .don't know what any of it does. thank you
- 1999_0304tools0012.JPG (131.02 KiB) Viewed 2057 times
Re: what is this??
Its a punch, chisel, holder, a older one. You have some nice tools in the pic. a few hard to find ones too.
tsmith1
Re: what is this??
I don't know where you live but it is all for sale I am in riverside california
oldtom
Re: what is this??
Hi all could start a new thread here identify the tools,see otc chain wrench,vice grip chain wrench .grease cap pliers ridged strap wrench
Re: what is this??
Hard to see some of them we need better pics but for starters.
A: 3 pieces are valve spring tools for flat head engines. There is another at the bottom in the same row.
B: Door handle/window crank horseshoe clip remover.
C: Dust cap remover - used on hubs of non drive wheels typically front wheels on RWD cars and trailer axles.
D: Flywheel turner.
E: Brake spring pliers.
F: Steeldraulic pliers.
G: Chain wrench two versions - used on pipe or irregular shaped objects. The red plastic one is a variation.
H: I believe this is a disk brake pad spreader but need a better pic to verify.
I: Tubing benders 3 different ones. The piece net to them with the off white plastic hemisphere is also used to bend tubing.
J: Hydraulic lifter puller.
K: More brake spring pliers.
L: Carb adjusting tool. Also used on GM distributors to adjust the dwell on points.
D: Flywheel turner.
Users browsing this forum: Semrush [Bot] and 129 guests
