New tool I invented
- HLAV1
- Your Location: INDIANA
New tool I invented
So when I kept running into the issue to remove ball joints or tie rod ends with no air and not having a full size pickle fork I invented this. I never owned regular pickle forks, all of mine are for an air hammer and I know I am not the only one that is in this situation. So I came up with a way to mount the air hammer forks or any other air hammer bit in this handle. The chuck on it is a quick release from an air hammer so it even holds the Snap On non turning bits correctly. I chucked up an old semi kingpin in a lathe and spun in down to size and I fit the chuck over it. I then drilled and rounded off the internal to hold the bits and I drilled the three holes on the perimeter to hold the chuck in place. I added non slip sticky grip tape to it and it works perfect, I have hit it with a drilling hammer and sledge.
- IMG_20171206_2121064.jpg (86.87 KiB) Viewed 22072 times
- IMG_20171206_2120326.jpg (188.62 KiB) Viewed 22072 times
- IMG_20171206_2120040.jpg (96.76 KiB) Viewed 22072 times
- HLAV1
Re: New tool I invented
I have yet to find a bit that this did not work with.
- IMG_20171206_2121322.jpg (84.57 KiB) Viewed 22071 times
nice job.
rdwaaw
- Your Location: Minnesota
I like it!!! Should transfer the energy from the sledge well!
I have a set that can be used either way, air or sledge, by changing drive end. A bit light at times!!
- HLAV1
I have seen those where the fork end can screw on different things, but you are limited to just the several pickle forks, this can any air hammer bit.
Users browsing this forum: Ahrefs [Bot] and 161 guests
