F-70N Lever
F-70N Lever
Is there a way to remove the lever from the pawl and reassemble the two?
Re: F-70N Lever
If u use the correct size punch u should be able to do it. There are about 4 diff switches on that model, if u ruin it I have a late model replacement
Re: F-70N Lever
Thank you once again!
