I am not sure if anyone is aware of this, but I was able to order two cans of Snap On Red spray paint. The part number is REP12A, and you can't order it only..you must call corporate.
In case anyone is curious about why I need it....I found a real treasure on eBAY....say hello to KRA149B.
Snap On Red Spray Paint
- jszesq
- Your Location: Evanston, IL
- KRA149.png (133.16 KiB) Viewed 21818 times
- Snap Red.png (170.7 KiB) Viewed 21818 times
Jordan S. Zoot, CPA
E: jszesq@aBIZinaBOX.com
retired-snappy
- Your Location: MA
Re: Snap On Red Spray Paint
Hi, How much paint did you end up using? Did it take both cans?
- Your Location: Anglesey UK
Same box as mine! Mines full of everything 3/8 drive and 1/4 both imperial and metric and anything else I could fit in it. I use it all the time
- C0CD4F6C-D7DB-4094-95D8-EF40D61A842F.jpeg (62.36 KiB) Viewed 21172 times
- A4A281A1-B566-4569-96C7-E15EAA882972.jpeg (62.41 KiB) Viewed 21172 times
- C50F1275-1671-4C7F-91CD-00F39E25F85F.jpeg (62.48 KiB) Viewed 21172 times
Bottom draw
- 51B57A57-558D-428A-96E7-C7B81C92577C.jpeg (68.73 KiB) Viewed 21172 times
7985
- Your Location: MA
Incase anyone wants to save $27.00 per can, Krylon Banner Red is almost a perfect match (dont use the industrial versions of Krylon Banner Red!!!), Use the cheap $3.99 per can stuff (it sprays 100% better and matches almost flawless)
Users browsing this forum: No registered users and 29 guests
