ONE OF THE "3" RARE 7/8" DRIVE RATCHETS??
dimwittedmoose51
Your Location: NE Iowa
Post by dimwittedmoose51 »
Got this at an auction Saturday. Alloy Artifacts had no info on it and prolly shoulda come here first. No part number on it and the patent applied stamp makes me think it might be an early 7/8" drive. The female part is 5/8" and the male plug part is 7/8". Was wondering if it might be the center rat in your "Socket set" section for "3 rare 7/8" drive tools" photo. Gonna keep it regardless. Does have a slight bend in the handle, maybe a 3/16" gap at the center when laid on a flat surface. Currently soaking in ATF to see if it will loosen up the pawl and/or spring. Rather not take it apart and risk reslly screwing it up.
7/8" side of it
7/8" side of it
dimwittedmoose51
Re: ONE OF THE "3" RARE 7/8" DRIVE RATCHETS??
Here's the last 2 photos
The plug comes in and out nicely while still being tight.  Rat mechanism wiggles ever so slightly.  Green paint should come off easily. The oil hole cleaned out nicely
5/8" side w/ the lock pin functional!
Sometimes you just get lucky. It is a 7/8 dr rat. from the late 20s The only diff in the 5/8 and 7/8 on most all SO rats is only the plug. So, if you cannot fix it, get a 5/8 rat with no plug and use this plug. Nice find.
dimwittedmoose51
Thanks Mom!!
DM&FS
Users browsing this forum: Ahrefs [Bot] and 111 guests
