Blue Points Ignition Wrenches.
This thread belongs here but I also posted it at The Garage Gazette. Came into possession of these recently and I was quite excited. I believe the Blue Points name was not used after 1929 so when these were new they could have been used on a new Model T or new Model A.
The set was eight pieces up to 7/16 when I got it.
In a real twist I had the 1/2.
There are a couple features I consider a bit odd. One is the 7/16 and the 1/2 have the name upside down relative to the rest.
Another is the wrenches seem to have been made from a limited number of forgings and broached to size. This would seem to indicate the forgings may have been bought and broached in house.
So I believe these were made in the 23-29 time frame and they were probably made at different times - certainly the name stampings are a little different font wise. None the less I am really pleased to have found them.
Re: Blue Points Ignition Wrenches.
I think they Would probably date 27-29. Some were made with the about 15 degree offset and some with no offset, you can see one with the offset in your pic. Hard to find, you got lucky.
Users browsing this forum: Ahrefs [Bot] and 114 guests
