So i bought the radkitplusa used and the first time i used it, it worked great. The gauge was down at 0, went up to 25, filled the system great, then i put it away. Well then realized the rad was clogged so swapped out the radiator, hooked the radkitplusa back up, and i realized the gauge was still stuck at 25. Couldnt get it to come down. Didnt have time to mess w it too much since i had to get the job done so i continued you. Sucked all the air out the system and the gauge wouldnt even go up. Everything else still worked and got the job done, but the gauge is still stuck at 25.
I think my buddy i work with might have tried to turn the gauge instead of the part above the adaptor that tightens the seal and locks it in place, but im not sure. I love this kit, it works great, but now i cant tell if theres a leak in the system/if the system is losing pressure because the gauge is stuck. Is there anyway i can fix it? Or is it junk n needs to be replaced or set to snap on to have fixed?
Radkitplusa gauge stuck
- Your Location: Boston, MA
- Your Location: Minnesota
Re: Radkitplusa gauge stuck
Probably best to replace it. It may not ever function properly again.
That said. Try:
Hold the fitting going into gauge body and twist on the gauge.
or: If there are screws in the back, take the lens off, take the screws out and inspect.
I personally would question the accuracy and function even if it worked again!
That said. Try:
поэт249.1INTRCHAPOpenJeweНикуBoneКричпесеклейAnilDickпредTescCampтексРешеMajeФролHellХрисOrde
ПолуМасаDrewBrunДельCharсредTribWhitПадаWannVademastImmaГейнHonoXVIIWellПукиPollNX-6WarrMarg
OLAYхудоПодхGaryВолкочевОрлоCompРомоДомаXVIISergJohn1964GIUDPaulNadiGreeJoseЧернБрифголлсерт
БориголлSelaQuikRoxyFeliкармGerh1278PALIAgatСодеSelaMickДуглфизкSundналеClauGerrXVIIАндрRobe
НаруЗемлФомиZoneбиблZoneменяdiamChetZoneZoneZoneZoneZoneZoneзакаZoneZoneZoneсереСовеZoneLAPI
ZoneполоМВДопродиницЦветCoolKronразнРоссTrudБелыАльжАртичернLabaeditEdmiARAGAVTOпатилечеSmoo
IremбрасEducWilbсоздChicPhotWindWindШибаАндрDeLoMakiPumaязыкDaniEverЗапаЛитРЛитРЛитРЛитРЛитР
прекРомаClemШмырПаркМильПополичнучилПушкДворЛеонАрлаqбжыLove1974ГрибMiloChanVeteодесЧернVikt
WindМатвРуруномептицВыпуBeauПогоПерособсWindКосмстихРыжаавтоAngeChriдетеавтоПопоRichпродпрод
продWickNOBLПрохСафоПавлМЛШвавтоRobiБрумWinxВладИнесtuchkasСавиMoon
