Snap on S710 ratchet
Joseph36
- Your Location: Pennsylvania
Hello , I have a S710 ratchet that has alot of play in the faceplate and in the ratchet housing where the small gear rides. Is there any way to correct this ? Thanks , Joseph36
GTM
- Your Location: Somewhere in the USA
Re: Snap on S710 ratchet
I am really not sure about what you are describing to us. Is the cover with the screws loose and the screws will not tighten down all the way? If the ratchet is worn completely out you might try to have it replaced under warranty but the warranty department would have to decide if it is covered under warranty. Can you snap a few pics of it?
Users browsing this forum: No registered users and 92 guests
