Hi All,
Just got my hands on a MT-615D Anal-O-Scope. Problem is it has had the wires at the back chopped off leaving about 10cm sticking out the back.
Can anyone help by sending me a wiring diagram/instruction manual so I can figure out which wire does what?
Thanks!
Kev
MT-615 Manual/Wiring Diagram needed
pOiSoNmOnKeY
- Your Location: Isle of Wight
DHC120
- Your Location: Texas.. Is there anyplace else
Re: MT-615 Manual/Wiring Diagram needed
Monkey;
Only a year, or so, late..
I, also, have the Snap-On MT-615D.. I use to use it "on the line" (auto dealership) back in
the late '60's..
I also have a poor photocopy of the Anal-O-Scope's Operating Instructions.. Believe it or not,
the Snap-On Distributor in Dallas found an old photocopy and sent me a copy (of a copy ;-} )
I can make you the same offer, if you are still interested.. Likewise, I can detail-out, in
writing, the "Connection To The Car" wiring info.. colors and connections..
Believe it or not, I still use my MT-615D several times a year.. the Vertical and Horizontal
"hold" adjustment has gone wonkey, but I believe that is a result of the four 6AT6 vacuum tubes
inside the 'scope's housing.
Let me know which you want... the color code/connection info, or a bad, but readable,
copy of the entire Operating Instructions (mailed via USPS)...
Charles.
the late '60's..
Charles.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 1 guest
