I need to replace the screws that are holding the ratcheting mechanism plates on the 3/8th and 1/2 inch dual 80 sealed head ratchets. Google shows so many results that the answer I am looking for is buried. What I need to know are the screw specs for the screws that are holding the plates to the body. size, length, tpi...
Thanks ahead.
Scre spec for dual 80 ratchets
pcm81
- Your Location: USofA
Re: Scre spec for dual 80 ratchets
You should contact Snap on customer service, they would send you the kits for free.
