Roll Cab Handle
- sierra
Roll Cab Handle
Need a roll cab handle for 1980 KRA-380 roll cab. It looks like the handle on this roll cab in the attachment. Thanks, sierra
- roll cab
- Snap on box.jpg (216.21 KiB) Viewed 5165 times
Re: Roll Cab Handle
Can you give the dimensions from center hole to center hole, I may have a older one that could work.
- sierra
Re: Roll Cab Pull Handle
snapmom, Thanks for reply on roll cab pull handle! I will get dimensions tomorrow or Monday A.M. I have the roll cab at local shop getting powder coated. Thanks Again, sierra
- sierra
Re: Roll Cab Handle
snapmom, There are 2 holes each side, 4 total. The holes are 12 3/4" apart center to center. The side holes are 1" apart center to center atop each other. See Attachment. THANKS! sierra
- handle measurements
- Handle Measurements.jpg (76.46 KiB) Viewed 5140 times
Re: Roll Cab Handle
Yes, the one I have will work, has bolts and guards etc. its used but in decent shape.
