vintage 1/4" drive socket/drive set 120A TM-B
ghougham
Your Location: Seattle, WA, USA
Post by ghougham »
Hi folks,
Newbie here on the forum. I had the cutest most useful 1/4" drive socket/ratchet set way back in the late 70's but it got lost (i.e., stolen) and I never replaced it. Now I want one! What I had was the 120TM-B standard set of 20 tools that came in the little steel box. I just found a decent example of that red box online (which is KRA-255), so what I'm now looking for are the 20 tools that came in it. The set is listed on p. 43 of the 1978 catalog here, but I'll try to list them out here as well. These all more or less seem available on Ebay (did they change the design of these item numbers over time? I want them all to match), but if there is expertise here to help me out to make sure I get the right ones that would be ideal. What do you think it will cost me? Any leads most welcome! Thanks, all!
TM-4A long shank drive (black handle)
TM-6 socket 3/16
TM-7 socket 7/32?
TM-8 socket 1/4
TM-9 socket 9/32
TM-10 socket 5/16
TM-10F breaker bar
TM-11 socket 11/32
TM-12 socket 3/8
TM-14 socket 7/16
TM-16 socket 1/2
TM-18 socket 9/16
TM-70B ratchet wrench
TM-408 socket 1/4
TM-410 socket 5/16
TM-412 socket 3/8
TMU-8 universal joint
TMX-2 2" extension
TMX-4 4" extension
TMX-60 6" extension
Cliftonves
Your Location: Hungary
Post by Cliftonves »
Hi Lauren
Unfortunately the only way Ive found to tell for sure is to check what is stamped on the crownwheel. I appreciate your looking though.
Regards Rsfruitbat
Users browsing this forum: Majestic-12 [Bot] and 1 guest
