3/4 drive tools 36-38
Need some s/o 3/4 tools date code 36-38. Buy or trade.
toolnut
Re: 3/4 drive tools 36-38
Are those the L series or the LDH? Single or double broached?
12 pts. LDH. with the square cut inset for the retaining ball.
crankshaftdan II
- Your Location: wisconsin
I have 2ea LDH342 1 1/16" x 12 point--the date codes are 39 & I think 33?
Hi: Thanks but I have that one. So what is that odd socket with the slots cut out, is that a factory cut out?
crankshaftdan II
NO, I don't believe that the factory would have intentationally milled two flats and obscured the part # and size! Picture attached.........Crankysnapmom wrote:Hi: Thanks but I have that one. So what is that odd socket with the slots cut out, is that a factory cut out?
- img_0133.jpg>
- IMG_0132.JPG (237.04 KiB) Viewed 48597 times
crankshaftdan II
crankshaftdan II wrote:NO, I don't believe that the factory would have intentationally milled two flats and obscured the part # and size! Picture attached.........Crankysnapmom wrote:Hi: Thanks but I have that one. So what is that odd socket with the slots cut out, is that a factory cut out?
- IMG_0131.JPG (244.44 KiB) Viewed 48595 times
crankshaftdan II
The darker socket from L to R(2nd one) has been traded away-evrything else still available...Thanks....Crankycrankshaftdan II wrote:I have 2ea LDH342 1 1/16" x 12 point--the date codes are 39 & I think 33?
ranger
- Your Location: newyork
Hi Snapmom. I have a 3/4 dr. L112 Breaker bar head with a '37 date code. Does this help you?
Thanks, but I need the L52 bar.
